D DonIsHere Senior member Aug 3, 2000 592 0 0 Sep 23, 2003 #1 I would like to make a pic with one side that fades. Example I have Photoshop but I don't know how to do it. Can someone help me out? thanks, don
AgaBoogaBoo Lifer Feb 16, 2003 26,108 5 81 Sep 23, 2003 #2 Make a new layer Set Opacity to like 30% Create a shaded region using the shader button on the new layer
D DonIsHere Senior member Aug 3, 2000 592 0 0 Sep 23, 2003 #4 Originally posted by: AgaBooga Make a new layer Set Opacity to like 30% Create a shaded region using the shader button on the new layer Click to expand... Where's the shader button?
I illusion88 Lifer Oct 2, 2001 13,164 3 81 Sep 23, 2003 #6 You could use a layer mask and a few gradients. Or just a gradient on another layer fading to transparency.
brigden Diamond Member Dec 22, 2002 8,702 2 81 Sep 23, 2003 #7 You could just stick your thumb on the lens.
F Fiveohhh Diamond Member Jan 18, 2002 3,776 0 0 Sep 23, 2003 #8 I used to know how to do it there was a decent tutorial on about.com. try there..
