My drive rails came in a white box that came in the case. I ordered for onvia a while back. You didn't receive any boxes with drive rails and screws and stuff?
They are long, white and plastic with metal ends. You screw them to the side of your cdrom with the metal ends point out at the face of the cdrom, then as chemicalagent said, you slide them into the grooves in the drive cage.
