- Aug 27, 2004
- 6
- 0
- 0
Okay, this is my first rig that I have built and I keep getting this error with my computer. Missing NLTDR Ctrl Alt Del to restart.
I know that it is a missing a file and the file is associated with Winxp. I formated this drive on this new via winxp cd And now it pops up with this error I have read up EXTENSIVELY on almost every possible solution to this problem. But for some reason when I try to put in my Winxp Pro cd, it won't read it before the NLTDR message. I have CD rom set to boot first in the bios.
My system specs are
Athlon 64 3400+
MSI K8N Neo Platinum
SeaGate Barracuda ATA II Hard Drive
Sapphire Radeon 9800 Pro
Sound Blaster Augidy LS
I am totally and utterly lost on this and would REALLY REALLY appreciate help on this. If I can't get this worked out, I will break down and buy a WD raptor or something to replace it.
My system specs are
Athlon 64 3400+
