HELP: Grammar Nazis Welcomed
yosuke188
2,726
I am of the firm belief that this problem can be fixed.
Now I know that sounds just weird (and probably wrong). Please make it better while keeping its formality.
HN
8,186
4
I firmly believe this problem can be fixed.
(Oh, and "grammar" ;))
yosuke188
2,726
OK I am embarassed at that all too common mistake.
Are there any other suggestions?
This is like an opening to a persuasive speech, and "I firmly believe..." doesn't sound too good.
Jun 4, 2005
19,723
Yours is better, assuming we're trying to trim down the sentence and remove all redundancy.
91TTZ
14,374
Dat sh!t BROKE
Safeway
12,075
11
Originally posted by: spasticnationboy
I hold firmly to my belief that this problem can be corrected.
This sounds the best, it just fits.
Problems aren't corrected, they are solved. PROBLEM SOLVING.
Sep 29, 2004
18,656
68
Missing a coma?
91TTZ
14,374
That sounds awkward. There are two prepositional phrases in a row.
yosuke188
2,726
I only see 1? :confused:
Perhaps you have something better? If you do, please share.
BG4533
1,892
My exact language would depend on the problem and possibly my ideas about solving it.
Based on what is here though:
I am confident this problem can be solved.
91TTZ
14,374
I believe that this problem can be fixed.
There's no use making it more wordy or awkward.
JulesMaximus
74,598
998
Lay the smack down on me homes, we can fix this sh!t yo!
LanceM
999
You want fix? I get you fix. Good, yes?
Ahem, I've always preferred including "that" in my wording. It holds more power when spoken.
EDIT: As in, "I believe that this problem can be fixed." Unless you are looking for an alternative to "problem" or "fixed," I think you've got your winner.
Jun 4, 2005
19,723
:thumbsup: Puts more emphasis on the situation.
