HELP got some problem with the geforce2 MX 400
The Green Bean
it is a 64 mb card and it used to work fine until today.(3 days old) .....
i installed direct x9 and now display property and directx both show the card as a 32 MB one
Wots wrong.plz help
welcome to the forums🙂:beer:
try uninstalling detanators from control panel
use driver cleaner
then install latest drivers from nvidia, hope this helps
um i dun really get u but i uninstalled the drivers from system properties.then reinstalled it.nothing happened.....
could this be a problem with direct X????? (ver 9)
thanx for the promt reply
hatim,he means download Driver Cleaner 1.9 from
here ,unzipp it and follow the readme file instructions which I`ll paste below.
nVidia:
1. Unplug nic card or modem from net or disconnect
2. Remove nvidia from add/remove programs
3. Reboot into safe mode (F8 during boot up)
4. On reboot into safe mode winXP SP1 will auto detect and install drivers. Just let it do its thing. If you can cancel out of the auto install hardware wizard then skip the rest and run Driver Cleaner! If you can NOT cancel out of auto detect wizard then...
5. Navigate to device mgr->display adapters->highlight nVidia and click uninstall or remove but don't reboot
6. Run Cab Cleaner (not needed, but recommended)
7. Run Driver Cleaner
8. Empty recycle bin and reboot
9. Install the new drivers
For other Operating systems
nVidia:
4. Run Cab Cleaner (not needed, but recommended)
5. Run Driver Cleaner
6. Empty recycle bin and reboot
7. Install the new drivers
Cab Cleaner don't need to be used on W9x/ME
this sounds pretty complicated.............one last try..otherwise ill use desperate measures...format......then ill noe where the prob was/is harware or software.....
nyways thanx for the help 🙂
hatim
Try downloading some kind of diagnostic program like SiSoft Sandra 2003.....to confirm whether or not your card is being detected as 32mb or 64mb. Does it not come up before the memory check when you turn on the PC, I would trust what it says there the most.
At an outside chance it could be that some of the memory chips are bad, what make is the card? and if poss, what memory chips is it using? Hynix?
Jamie
well....it works now.....there seemed to be a problem with the intel chipset drivers and a conflict occoured....everythings fine now............thanx for the help
his i interesting...............
Wen ever i install cnc generals, windows changes my chip type and string type to Sis......What is wrong???
please help!!!
