Lmao the OP is an idiot. Read some of the threads. Firstly he was running a raidmax... he 'needed' his processor to run @ 5ghz and close to boiling point. To this point afaik he has not gotten a proper voltage reading on his processor since he's been using cpuz. God only knows what kind of ventilation he has in his (raidmax?) case. You should send in all your overclocking endeavors with the RMA request. You'll surely be laughed at for blaming Gigabyte for your idiocy and carelessness.
edit: really? Microcenter gave you a new mobo? You should be content and quit your whining. Someone already paid for your mistakes. Get rid of the ludicrous oc and be done with it.
You could teach him rather than berate, no? We were ALL idiots at one point. I almost blew up my first [self-built PC] motherboard, A7N8X-VM/400 - tightened it down without standoffs! Called ASUS tech support, told him the entire computer was squealing, he immediately asked me to check for ground/short and was smart enough to suggest "checking the standoffs."
HollowRopes - set realistic expectations. I've got one of the obnoxiously expensive heatsinks mentioned in this thread, and I'm staying below 4.6 GHz/1.35V - not because it won't go any faster, but because I don't want to melt anything.
Do not expect a spectacular overclock or longevity from your hardware with a Raidmax PSU - however, you do
not have to spend $100 for a good one. Some people here call it "insurance" - I call it "luxury" to go and splurge on a 850W PSU "in case" you need SLI or CrossFire.
You haven't mentioned your graphics card - but I'm guessing you don't have a GTX580+ - so this PSU will be a huge upgrade from your RAIDMAX -
http://www.newegg.com/Product/Produc...t-_-17-371-031 - People say this is a rebadged Seasonic, so it's a GOOD power supply.
As far as cooling/overclock is concerned, do you really want to run at 1.42V all the time? Without using a multimeter? I'm too lazy to actually check my voltages, so I don't go any higher than 1.35V. Unless GIGABYTE sold me a total turd of a motherboard, it couldn't possibly be reading more than 0.1V out of spec - so I'm safe.
Clock it down, turn the voltage down, and you'll be fine with the 212+. If you really want 5 GHz and all that voltage, you need to get a Megahalems, Noctua, Silver Arrow, etc. These are pricey, check the FS/FT forum, there are a couple of Noctuas in there going cheaply!
