I attempted a client install over the network to a remote client. I entered my user_info.sah file, set my local proxy, and selected the remote machine I wanted to install the client on. It appeared to go fine but when I checked my SetiQ log the client never got a WU. I browsed to the machine ( \\machinename\c$) and sure enough there's a c:\stcli directory there. Hmmm... After thinking a second I didn't include the port when I set my proxy. I use port 5512 on my SetiQ. What can I do to fix this?
I attempted a reinstall with the correct info but it didn't work. Is there a way to remotely uninstall the service? Can I correct this another way without having to interrupt the user?
Thanks!
Thanks!
