Help finding EPYC motherboard
bobsmith1492
3,875
Hi all,
I'm looking for a workstation level motherboard for an EPYC processor and am finding rather skimpy results.
I only need a single processor. The only one I found had 10gbit Ethernet with a funny connector for fiber that I can't use.
https://m.newegg.com/products/N82E1...MIr6r_66an1wIVBWt-Ch27EQtqEAQYASABEgJRMfD_BwE
Any suggestions?
I'm expecting to use the machine for EMC and RF simulations with a GP100 card and need the 8 memory channels for bandwidth. I like the idea of a single processor to get my memory bandwidth which is why I'm looking at the EPYC vs. a dual Xeon. Cheaper, too.
Thanks!
tamz_msc
3,865
3,730
That would be problematic given that boards dependence on riser cards.
OP: A single socket SP3 board is kinda counter productive. The market for a system that exceeds what Threadripper can provide but only want a single socket would be exceedingly small. My recommendation would be:
https://www.supermicro.com/Aplus/motherboard/EPYC7000/H11DSi-NT.cfm
He's very clear why he wants a 1P board - for eight memory channels from one CPU, not PCI-e expansion.
To the OP, you could just get a 10GbE Intel network card if that's what you want.
XavierMace
4,307
450
Yes, I'm aware of that. I was explaining why he's not finding many results.
My point regarding the PCIe slots (which he already stated he will be using) was if you put the suggested Tyan board recommended by sdifox in a standard tower case that supports EATX boards, you're going to find it difficult to use any PCIe cards.
Topweasel
5,437
1,659
What he will probably want is something like one of the H11SSL models from Supermicro when they hit. I think the big hold up is that AMD has only just started to ship Retail versions of the chip recently. Give it some time and Asus and co will have more workstation oriented boards for it.
bobsmith1492
3,875
Thanks for the comments guys!
I did see that Supermicro board which is pretty similar to the Gigabyte.
Yes, it seems just a bit early for an Epyc system.
I'm fine with a dual socket board too and just using one if they work that way.
I don't need 10 gbe, just a single gigabit port. Supermicro had a board but still had the dual 10gb fiber. Hate to spend 700 on a motherboard and have to add a silly Ethernet card, plus pay for expensive bits i don't need.
XavierMace
4,307
450
I'm not familiar with the work you're doing, how much performance are you actually gaining with 8 channel memory vs 4? If you can wait, I'd agree with with Topweasel on the H11SSL But the professional side of me then asks why you're not going prebuilt, are you sure about your requirements, etc.
