Looks like humidifier is 2 wire... googling up the wiring on that for smart thermos
Unfortunately your system is beyond my area of expertise and I do not know how much more help I can be. I don't even know if running a new wire from the thermostat to the furnace will help. I just don't know enough about older systems like this to feel comfortable enough to give you anymore advice.
From experience that can be tough to figure out. I’d get a picture of all your wires at the thermostat, furnace/boiler and humidifier
Send them over to whatever company you want and ask them if it’s compatible.
I know my nest has a humidity setting but I’ve never used it since I don’t have one.
Plan b could be to buy it from Home Depot and try installing them see what happens. Home Depot is very easy on returns.
Good work you’ll like the nest
Too damn chilly.
However I’ve done the same pre-heat pump
Congrats man! Glad to hear you got it hooked up and running although the Nest isn't exactly a "simple" thermostat like you mentioned in your first post.
Don't forget to fill out the rebate form for We-energy. The third gen Nest is on the approved list and you can get $50 back.
I'm sure you have but just making sure but did you turn on both heat and cool to make sure they work? With 2" of snow coming I'd hate to see you turn on the heat only to not have the Nest send a call to heat to your furnace.
Cool I figured you did but I just wanted to make sure.Heat worked fine. I actually can't even test the A/C as the nest wont turn it on until its over 60*
I still have the wires and bracket of the old thermostat hooked up in case of emergency. Once the Nest is running for a week or so (actually pumping out heat) I will go back in and undo those wires and remove the bracket from the wall.
Sometime in the near future, I will probably get a professional out to get the humidifier running off the nest too. The whole wiring layout is just too confusing and hacked together from what I can tell for me to make sense of it. The whole system could use a "tune up" I'm sure.
