- Nov 29, 2005
- 270
- 0
- 0
I just upgraded to the following parts:
mobo: GIGABYTE GA-EP45-UD3P P45 775 R
cpu: e5200
heatsink: stock that comes with e5200
videocard: palit hd3870 512mb
powersupply: antec earthwatts 500w
ram: ocz reaper 2 gigs(i checked to make sure this was supported by mobo and it is)
did a clean install of windows XP home, however the DVD drive is not functioning in windows. what is strange is that i was able to boot from the windows install cd to complete the installation using the dvd drive, but once i get to the desktop, the dvd drive does not work and instead appears as "removable disk(d: )" in my computer. it gives me some I/O error if i try to open it.
this is a problem because the driver disk that came with the mobo is a DVD...if i cant use the dvd drive, i cant install the network card drivers or any other drivers(and since i cant install the network drivers, i cant get online to get any other drivers). if i try to put the DVD into my cd-rw, and then click "explore" for that drive, it just shows up as empty. however, if i boot from the mobo DVD, then it does work and it takes me to some kind of recovery program that i guess i can use to create a backup image. so, it seems like neither the DVD, cd-rw drive or the dvd drive is defective.
the cd/rw and dvd drives are just cheap off brand stuff, but they worked absolutely perfectly prior to me doing this upgrade last night. i am not sure if they are ide or scsci, but i can tell you that the cable goes from one drive into the other where the same cable then splits and goes into the motherboard(i am pretty sure the motherboard says ide where i plug it in). i have a power cable plugged into both drives and they open and function properly. as for bios, i have not touched anything and just let everything boot set to auto.
does anyone know what the heck is going on? thanks.
cpu: e5200
