imported_Kensai
- Nov 11, 2004
- 10,855
- 0
- 0
The TPII 550W is a good PSU too, normally I prefer Seasonic S-12 for silence.
Either way, I prefer Antec over Seasonic.
Originally posted by: Bona Fide
Dynamix, you can get a better price on the TPII-550. Guess where?
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
Originally posted by: Dynamix3D
I think for now I'm going to just stick with stock. Because I really would hate for something to happen and kill a $500 video card. I think if ever I decide to use the aftermarket cooling, I'll do it later on when the card isn't worth so much anymore, and it starts to show age, when every few FPS will count in overclocking it. Right now there really is no need to even overclock it. The game I play most, which is CSS runs at 120-200fps with settings MAXED out completely, and my 1680x1050 resolution.![]()
Also I do think the stock cooler looks better than the Zalman, even though it isn't that important on how it looks, its just another reason maybe to keep it on, lol.
After finding out today that eVGA warranties cards that have the OEM heatsink replaced, I went ahead and decided to put my Zalman VF700Cu on my precious 7800GTX. Well, this was a great idea considering, it dropped my idle temps 13C, my case temps 5C, and my cpu temps 4C. The OEM heatsink is good considering that it is quiet, but obviously doesn't do a great job of cooling. I think the whole reason the card has a quieter stock cooler is because it uses less power than the 6800 series, thereful it runs cooler, so they don't need a fan as powerful as on the 6800's. But yes, the Zalman is here to stay. It didn't change anything as far as noise goes. The Zalman has a slightly smoother sounding fan, but you can't really tell the difference unless you have the case open and you are listening for the fan anyway. The big deal is the drop in temperatures that I just recieved. Definately something to consider if you are buying a 7800GTX. Well worth the $32 that it costs.
Originally posted by: kman79
I'll be purchasing the same Cooler tomorrow morning when I get out of work.
I was wondering how much did the cooler temps improve the overclock of the card if any at all. That's if you overclock, do you overclock?
Well slapped the Zalman on just a few minutes ago. Idle temps went down 6C and get this, Max load Temps went down from 78C to 62C. Packaging says it can lower your temps by 10-15, and it sure does. Definately a great cooler. I got the all copper one, with Vantec Copper RAM Sinks.
In terms of overclocking. I got it at 499/1320. Adds another 120 points in 3DMark05 and 13FPS on rthdribl. For those that dont know, it's a little visual program that demonstrates HDR, very taxing on the video card. Although I still can't get it to run full screen at 1600X1200, it does now run 1280X1024 at an average of 42FPS where before it was an average of 29FPS. So it's a good improvement.
Coolbits and rivatuner won't let me run higher than 499. I'm not sure why, but I'm thinking about trying the KO Bios to see if it'll let me run higher. I don't get any sort of artifacts at 499/1320, so I'm not sure why it won't let me run higher
