NathanStapleton
Hello,
Tried to find the answer for this question in the last couple of days, googled and googled for ages but to be honest im still confused. I know the official site says no compatibility with this socket. Read that the H90's backplate has holes for lga 775, but the brackets don't have these holes on them. Some of the reviews on the internet(quaility sites) do say that the H90 is compatible with lga 775 boards, some say something else, and reliable shops has lga 775 compatibility under the H90 details. I would do modding if necessary to make it fit.
Any ideas?
Did anyone try this before ?
Don't want to spend £70 on a cooler what won't fit my mobo.
Thanks in advance.
Nathan
Any ideas?
Thanks in advance.
Nathan
