I have a Silverstone 120mm case exhaust fan that came with my case - I believe it's the same case fan that you can buy seperately, but mine didn't come with the fan controller.
I would like to be able control the fan speed because it's blowing more air then I need and I'd like it to be quieter. (apprently the Silverstone 120 gets 100 CFM at full speed, and will run fullspeed without the fan controller)
I'm hoping I can get one of those Zalman Fanmates to control the RPM, but one thing is confusing me....
The fan has three wires... the red and black wires go to a fullsize 4-pin molex connector (connected to the powersupply) and the yellow goes to a 3-pin motherboard connector - Will the fan mate work if I connect it to the 3-pin, and the 3-pin to the motherboard?
I have the Asus SK8V motherboard and an Opteron 146.. on which I enabled "Q-fan" control.. which doesn't seem to do much.
Thanks in advance,
Laurence
Thanks in advance,
Laurence
