Help! Computer making noise on startup
desi01
52
I just finished setting up a new computer and went to turn it on. When i pushed the power all it did was make a loud noise. nothing came on the screen but the fans and lights worked. WHat could have happened. plz help!
desi01
52
Specs:
MSI K8N Neo2 Platinum
AMD Athlon 64 3000+
PNY GeForce 6800
Mushkin 512MB PC3200 RAM
Seagate 10gb
Antec 430W
TT Tsunami
Didn't change any settings at all.
Feep
224
were you able to tell where the noise came from?
Does it do it everytime you turn it on, or just the first time?
desi01
52
Dunno exactly where it came from cause i just turned the power off after it started. Also i wasnt able to turn the power off by the main power switch i had to turn the switch off on the psu.
is it possible the mobo or something else could have got shorted or is it just somthing like a wiring mistake?
desi01
52
Now that i listen the noise does seem to be coming from the psu but the fans on it are all working and other case fans are working too.
Feep
224
sure, but not everything works perfectely.
Sounds like everything in there is new, so something must be DOA
desi01
52
Is there some way to test out different parts to see which is bad?
and is there any possibilty that it could just be some simple mistake
-oh well i'll just look into this more in the morning time for some sleep :)
Feep
224
possible, but the noise doesnt really make sense
you could plug individual components into a working comp, if you have one availiable
desi01
52
Ok I think i've narrowed down the parts: It can't be the psu because the fan works and the so the psu must be working, it can't be the mobo because the nb fan on the mobo works perfectly when the mobo is the only one plugged to the psu, the hard drive and dvd rom all work fine, i don't think memory could cause this problem so that leaves the video card but why would it make noise like that? Any thoughts? Thanks for the help.
desi01
52
Oh my gosh i think I figured it out. When i was browsing around looking at other posts I realized that I forgot to check the fan on the video card and voila! It wasn't working and im pretty sure it should of been (i only have power hooked to the mobo so video card fan should work right?) If this is the problem i'll just go replace at compusa (good thing i bought it at a local store :) ). Thanks Feep for your help too.
superkdogg
640
Does your card have molex connectors on it? If so, they need power from the power supply, the motherboard doesn't supply enough through AGP slot.
desi01
52
Nope i don't think it has any type of connector on it. It doesn't have any wires coming of it. Its a PNY Verto 6800 card.
imported_Phil
9,837
Just because the fans are on does notmean that the PSU is working correctly.
biostud
20,250
7,382
Hmm. all other GF6800 have this connector as far as I know. It has a plug in the end, not any wires.
desi01
52
Oh man im so stupid. It does have a connector on the end now that I look at it more carefully :shocked:!!! Thanks so much for pointing this out.
I hope this solves my problem.
biostud
20,250
7,382
Oh man im so stupid :shocked:. It does have a connector on the end now that I look at it more carefully!!! Thanks so much for pointing this out.
Glad to be able to help :)
biostud
20,250
7,382
how has you connected your keyboard? USB? or keyboard plug? If the last, check you haven't inserted the plug into the mouse plug.
