I beleive the difference between using the cable and not, is that when you are using the cable it is playing the cd like any normal cd player. And just using the analog output to goto the harddrive were it gets mixed back into the sound by the sound card hardware.
Were as otherwise instead of using the analog out you can sample off of the cdrom digitally using software just like it was a data cd. This way the software can take multiple samples and neat stuff like that to get better sound quality by using the improvements built into modern 20x(+) speed drives.
I beleive that the alsaplayer program does that. Now I forget if it comes with the utils or tools package or you have to install it seperately, but it is pretty nice. The reason I think this is because when I use a normal cd player it plays thru just 2 speakers normally and the alsaplayer plays the cd thru all 4 speakers.. front and rear..
(actually both in front.. I use a cheap table top stereo with BASS_BOOST
sounding speakers that are all boomy and muffled sounding with a 17 dollar set of computer speakers that sound all tinny and distort horribly with any bass stuff.. I mix them together, spend 5 minutes balancing the outputs and turn down bass completely for the computer speakers and then I have a decent set full-range sounds!)
Did you use Winamp, in windows?
