- Oct 9, 1999
- 15,216
- 3
- 81
I just talked to the tech guy who came by the first time, he said the thing does not have a pitot tube as its a packaged air handling unit.
He said that he isnt sure why its blowing the heat towards teh sensor/electronics, says its most likely a problem with the burner and its going to be hard to diagnose..Says he isnt sure why its tripping, cause he isnt sure why the heat is coming back towards teh sensor and tripping it.
He suggested replacing teh entire unit, however I think its easier to do that then try diagnose the system, and I disagree with him on that, so I'll have to get a second opinion.
Any ideas what may be going with it. The unit is less than 8 years old. Installed 3/8/2005. Its a Lennox packaged air handling unit, 12GCS036X-75-5PB is the model #
