Help!! Calculus problem!!! help meeee!!!
Omegachi
Ahhh....i have a calculus final tomorrow!!! and i don't understand a problem 🙁
how do you find the horizontal asymptote of f(x)=(1-x)/(x+2) ??
i know the vertical asym. is -2 cause thats what make it undefined...
whats the horizontal one??!! ahhhhhhhhh. help
okay....nevermind, I figured it out. thanks anyways
i just take the limit as x->infinite, the answer should be -1
mimendo: setting f(x) = 0 will only find the x-intercept.
To find the horizontal asymptote, I would just plug inifinity for x.
the top would become -infinity, and the bottom would be +infinity, and i Know you can't devide infinity/infinity (techincally, it's infinity) but, it would end up being -1.
horz. asym. = -1
another way is to find the highest powers of x for the top and bottom and divide accordingly.
For here, we have -x^1 on top, and x^1 on top, so take out anything that's not the highest power of x and that leaves you with -x^1/x^1 = -1.
The horizontal asymptote is found by getting the limit of f(x) as x approaches infinity. (Also what number does f(x) approach as x goes to infinity. The 1 and the 2 in the problem become irrelevant because they affect the result less and less as x gets larger, therefore the answer would be -1.
As we do a linear degredation of the cotangent in question, it is absolutely imperative to know the vector coordinates of one's bellybutton.
<< OH god, brain is dead......Help me...you guys are CRAZY....... >>
On the contrary, Im not crazy at all. My answer was rooted in the very foundation of mathematical principle. 😛
