Help....Barton 2500+ running slow!
The Green Bean
6,506
7
ok I have bought a new MB and processor.
Barton 2500+ and MSI K7N2 L
Using CPU Z and in the initial screen, the clock speed is 1100MHZ. Isnt it supposed to be 1833? FSB is running at 100. Clock multiplier 11. Bus speed 200MHZ. Also my PC2100 Ram is working at 165 MHZ.
plz help
Confused :(
hatim
The Green Bean
6,506
7
I tried both....
Doesnt work. I change the settings in the BIOS and they remain changed. But on the initial screen and CPUz still show the same clock speed and FSB.
Cerb
17,484
33
86
Are you keep the RAM ratio? If not, have the RAM at 3/4 or so, so it's running at or under spec. If the RAM or CPU don't like the new speed, it should go back to defaults.
Mine does just what you mention if that happens: the BIOS settings are the same, but if I save and restart, it takes an extra second or so, and comes up at 133/133 (my board's defaults)
John
Moderator Emeritus<br>Elite Member
4
User Manual
Right now your memory is running @ 100MHz (11x100), and it may or may not work @ 166MHz. Page 47 in the manual shows that you need to have jumper J10 on the top 2 pins, and J11 should have a jumper over both pins.
Page 61 shows the advanced chipset features portion of the bios, and you need to set the following:
[*]CPU FSB Clock to 166MHz
[*]CPU Interface to normal
[*]FSB DRAM Ratio to 1:1
Hit the ESC key, then F10 save and exit. If your system will not post you need to set the FSB DRAM Ratio to SPD because your memory will not run @ 166MHz.
The Green Bean
6,506
7
ok now its fine...
actually the jumper on the mobo wa set incorrectly. Whenever the computer restarted, the settings were set as default...
txxxx
1,700
Originally posted by: hatim
ok now its fine...
Its a very useful jumper should you overclock via the BIOS - as resetting the BIOS doesnt reset the FSB on these boards for some reason...
