V vxmqzz Member Aug 11, 2005 70 0 61 Oct 14, 2005 #1 Tried to oc x2 4400 to 220 x11, also changed ddr bus speed to 220, after restart system is running but screen shows nothing. what's the problem? Should I take the batter off from the mobo? Thanks
L Lonyo Lifer Aug 10, 2002 21,938 6 81 Oct 14, 2005 #2 Reset CMOS (with a jumper), go to CPU/Overclocking forum, check the quick AMD overclocking guide and follow the instructions.
L Lonyo Lifer Aug 10, 2002 21,938 6 81 Oct 14, 2005 #3 http://forums.anandtech.com/messageview...atid=28&threadid=1497607&enterthread=y if you're lazy
J Jiggz Diamond Member Mar 10, 2001 4,329 0 76 Oct 15, 2005 #4 Or you cound try powering the system while pressing down on the INS key. If this does not work, check your mobo manual on how to reset the cmos.
