I am trying to build a PC that is high performance, yet as silent as it could be, without sacrificing cooling. (We definitely don't want anything melting!)
Did I mention that it will all be air cooled?
Basically I am trying to pick parts that have a good balance of performance and low noise, especially fans. I am hoping that by using proper noise dampening materials, and low noise fans, I will be able to accomplish this project.
I plan to use the following parts:
Motherboard: ASUS Rampage III Extreme
CPU: Intel Core i7-950 3.06GHz (overclocked to ~4.0GHz)
Memory: GeiL Black Dragon 12GB (6 x 2GB) DDR3-2000
Storage: OCZ RevoDrive 120GB PCI-E SSD (Boot drive,) WD Raptor 150GB, Seagate Barracuda 1TB.
GPU: XFX 9800GX2 Black Edition
PSU: Corsair HX1000W
NIC: Intel PRO/1000 CT
Sound Card: Onkyo SE-200PCI LTD
Enclosure: SilverStone TJ10B-W
Optical Drive: Pioneer BDR-205
Other parts:
CPU Cooler: Thermalright TRUE Copper
Card Reader: AFT PRO-35U
Acoustic Dampening: AcoustiPack ULTIMATE PC Soundproofing Kit
AcoustiPack EXTRA Foam Blocks
Thermal Compund: IC Diamond 24 Carat
Ram Heat Spreaders: 6 x EnzoTech DDR-C1
Fans: 5 x Noiseblocker Muiltiframe M12-S2 120mm (Case fans)
2 x Noiseblocker Multiframe M12-PS 120mm (CPU fans)
1 x Corsair Airflow 2 GTL (Memory cooler, not sure if this will fit.)
HDD Enclosures: 1 x GUP SMART DRIVE Copper (WD Raptor 150GB)
1 x GUP SMART DRIVE 2002C (Seagate Barracuda 1TB)
Lighting: 1 x Logisys 20" CCFL Frontal Light Bar
Bolded parts are the ones I am scraping from my previous PC.
1. I will be using this computer mostly for gaming (WoW, FPS, everything,) listening to music with Hi-Fi components, and recording (guitars, vocals, etc) once I acquire the right equipment for it.
2. My budget is very flexible, but it is around $2500CAD. The thing is, I am going to use a few parts from my previous PC that are still good in this new rig, so that will probably add up to another $1000 worth of parts.
3. I live in Canada, but not all the parts I want are here, so I will be buying my parts from Canada, USA, Japan and Germany.
4. I am an Intel and Nvidia fanboy; however, either ATI or Nvidia is fine for me seeing as they're both decent.
5. I intend to use my old PSU, GPU, a few harddrives (one WD Raptor,) and two SMART DRIVE 3.5" HDD enclosures.
6. I have looked all over the net, but I haven't found anyone trying to build a quiet gaming rig. It is always either about pure OC/cooling or pure silence.
7. I want to overclock my processor to 4.0GHz, but I am afraid that this might be too much for my cooling system to handle, I'll leave this up to you guys to critique.
8. I am planning to game at 1920x1080.
9. I plan to build the PC within a month from now, or at the very least order all the parts.
10. I understand, seriously understand that silence and overclocking do not go hand-in-hand, but perhaps it is possible if I use the right parts. Bring on the critique.
Thanks.
Other parts:
Thanks.
