Highmodulus
- Nov 10, 2005
- 153
- 0
- 76
If you are moving it around enough to tear up the old case, you may want to look at the sweet new Lanboy Air case Antec just released.
At the very least, in addition to purchasing the main parts, I plan to buy Noiseblocker fans. I just have some quick questions regarding which model.
http://www.noiseblocker.de/en/Multiframe120.php
I see atleast two solutions:
1. 2 x M12-P 2000rpm PWM fans for CPU cooling, which are at 29dBA max (what Axon recommended.)
5 x M12-S3HS 1800rpm at 27dBA for case fans.
or I could go slightly less fan power, less noise
2. 2 x M12-PS 1500rpm PWM fans for CPU cooling, which are 23dBA, significantly less noise than the M12-P, but less performance?
5 x M12-S2 1250rpm at 19dBA.
The Antec Performance series (P180 and related) are decent for keeping things quiet, but NOT for keeping things cool. To really quiet them down, you either have to go with low RPM fans and starve your components for air, or go with medium speed fans and deal with a bit of noise.
My FT01-BW is much quieter than the P182 that it replaced, and it moves a ton more air thanks to the 2x180mm fans and better internal layout. My FT02-B, with 3x180mm fans, was nearly inaudible while making the P182 look like a joke for cooling. That P182 had all of the stock fans replaced with Yate Loon D12SL's, and while it was very quiet, the CPU idled at ~50C. The FT01-BW is as quiet or perhaps quieter than the P182, and the CPU idles around 44C at the same ambient temperatures. On the other hand, when I upgrade the P182's fans to Scythe S-Flex F's, the cooling was a bit better but the noise drove me nuts.
The PSU you mentioned is the CP-850W. It's a much taller form factor, and ONLY fits the Antec P183, P193, and Twelve Hundred cases. Meaning, if you get that PSU and one of those cases, then upgrade the case later down the road to something from Silverstone, Lian-Li, etc., you have to upgrade the PSU as well. There are a few other rear-blowing PSUs available in the normal ATX form factor, such as the Antec Signature series and PC Power & Cooling Silencer (if it's still available). You'd probably be better off with a Seasonic X-series, though.
Anytime I see the term Extreme in a motherboard model name, it means you are paying more for it than it is worth. This is only my opinion.
Could someone look at the website and let me know what you think?
Seriously, OP. Just try the stock fans. 5 of ANY fan is going to be louder than necessary.
Also, I am planning to setup Wake on LAN (WAN, to be more specific) on this PC; however, after reading about it, it seems like only a few specific NICs support this function, and the Intel one does. Maybe the onboard ASUS Rampage III Extreme (which also uses an Intel controller) NIC works too, but I don't know. Perhaps I will try it out first before buying the NIC.
New goal: Build a performance PC with the quietest efficient parts I can get my hands on.
GPU: EVGA GTX 480 SuperClocked+
I should be able to keep the noise level fairly low, yeah?
New parts:
CPU: i7-950
-CPU Cooler: Thermalright Silver Arrow with an extra 140mm fan
Mobo: ASUS Rampage III Extreme
Case: TJ10B-W
-Case Fans: 5 x Noiseblocker M12-S2 OR M12-S3HS (My last question regarding which fans to use is still unanswered!)
RAM: GeiL Black Dragon 3 x 2GB DDR3-2000
PSU: HX1000W
-GPU Cooler: Accelero XTREME Plus
Storage: OCZ Vertex 2 120GB (OS)
Some kinda large HDD for storage. I am a bit behind on HDDs, what are some good ones for downloading and/or backing up data?
How am I doing so far, am I getting there? I figured that since I'm using quiet fans, and my PSU isn't exactly a noisy one, I should be able to keep the noise level fairly low, yeah?
