I had a computer custom-built for me about 10 months ago, including (I think these are the only relevant parts) an Asus A8N-SLI Deluxe motherboard, a Lian Li PC-V2000 case, and an Enermax EG651P-VE (FMA) power supply that was taken from an older Intel computer that I had built myself and used for about two years. Went away for Xmas vacation and when I returned this week turned my computer on and the chipset fan on the Asus motherboard was dead. I got a Swiftech MCX159-CU chipset heatsink and fan to replace it, took the whole computer apart last night, put the Swiftech on, and thought I had otherwise reassembled everything precisely as it had been. But when I tried to turn the computer on, nothing happened when I pressed the power switch on the case. Silence. Then I noticed that all the case fans, and CPU and heatsink fans were running even though the computer not powered up. Thought problem might be case switch (maybe it is?), so I pulled out all the system panel connectors (HDD LED, Power SW, Speaker, Power LED), plugged power supply back in, and all fans still came on. Same result when I unplugged the 4pin EZPlug connector from the motherboard. I did notice when I plugged the main ATX power connector into the motherboard that there are four more holes on the motherboard socket than there are plugs in this connector, and am wondering if I put that in the wrong place (I centered it in the connector, two holes showing on each side). I have plugged in the square 4pin ATX connector. Any idea what I'm doing wrong? Misconnected power supply (should all the fans be running when the case power switch is not even connected, no less turned on)? Bad case switch? Other? Any help would be appreciated . Thanks.
