CKent
- Aug 17, 2005
- 9,020
- 0
- 0
Originally posted by: dxkj
Originally posted by: RBachman
Can you even change most wireless routers' settings wirelessly? Anyway, option 2 = win. And when your ISP ditches you for downloading all that goat porn - you have an emergency connection to fall back on.
yes, once you are connected to it you go in IE and do 192.168.1.1 or whatever for the set model, and then you login. If the thing isnt locked down, the un/pw is either admin admin or admin password probably
BTW: I am NOT advocating doing this, its more than likely illegal.
Thing is, default settings (which most people use, and obviously these people are using if their router isn't secured) on wireless routers generally only allow settings to be accessed / modified from a PC hooked up by wire. I know this is how mine is; it's one of the first things stated in the manual.
