bankster55
- Mar 24, 2010
- 1,124
- 0
- 0
I have the deluxe mobo and looked around and found the thermalright 1156 bolt thru kit is their answer
$10 + shipping from frozen CPU
1155 and 1156 same bolt hole pattern
Just got them today (ordered 4 kits)
http://www.frozencpu.com/products/im...tl=g48c371s222
Fits great both ways
zero ram probs if you orient fan towards top
Fan pointed towards rear may have to remove fan to get closest blck slot access - only because some genius at ASUS went to single lock ram mechanism - it is a bitch to get the ram in
But tall RAM sinks no prob
So that now gives you TRUE, Venomous, IFX 14 Cogage type TR options. Doesnt say HR-02 but looks O.K.
Wanted to try new archon, but not sure backplate clears rivets - has two holes symmetric, no hole for third rivet
Edit: just noticed both the 120 and 140 fan noctua towers work
The plate itself only goes on one way to clear 3 rivets, but heatsink can orient either way
I like those plastic standoffs to raise over components
http://www.noctua.at/pdf/manuals/noctua_nh_u12p_se2_manual_en.pdf
