I can only get my favourite budget processor OEM these days so I'm after a non-stock heatsink fan for the CPU. I'm making a couple of budget systems so I don't want to spend too much on each if I can. As a whole the systems won't be too hot - built-in graphics etc. Microdirect in the UK is round the corner so I'll probably go there. Im thinking of one of these Akasa ones, or the Sharkoon one:
Akasa AK795CU
Akasa AK824CU
Akasa AK827
Sharkoon CUS3
Can anyone recommend any of the above, or suggest any other ones? Particularly if it's worth my spending a few more pennies to get something easy to install. It doesn't have to be perfectly silent, or icy-cool, just something similar in performance to the stock AMD model, and capable of being installed by an idiot. Thanks
Akasa AK795CU
Akasa AK824CU
Akasa AK827
Sharkoon CUS3
