Brainonska511
- Dec 10, 2005
- 25,056
- 8,334
- 136
I think it also depends on your heat pump. TechnologyConnections has a pretty good video set about these:
At around 8 minutes, he shows the table for a Mitsubishi heat pump that has a COP of 2.8 at 5 F. Granted, this is probably one of the newer, more expensive variants, but there are many more than can still have COP >2-3 at 20 F.
As for "sucking heat out of your house" - if the system is setup properly, it should just be turning off the indoor blower momentarily to run the heat/cool loop in reverse to defrost, so you shouldn't be experiencing any issues with indoor comfort.
Power draw is definitely going to be better than either traditional electric heating or traditional air conditioners. The biggest draw is that it's a lot more environmentally friendly than burning gas (or other fossil fuels) for heat.
