Heat pumps (air source)
Franz316
1,028
556
All the posts about heat pumps that I could find in the "Russia invades Ukraine" thread in P&N have been moved here. This thread was actually started by Atari2600 with post #22.
admin allisolm
Germany really dropped the ball the last two decades becoming so dependent on Russian fossil fuels. They should have begun transitioning to electric heat pumps many years ago.
Dman8777
426
8
I know a lot of people here in Germany who have built houses in the last ~10 years. They almost all have a solar system on the roof and heat pumps for heating. These systems are subsidized by the government to various degrees depending on the current administration. Generally, they can heat the house and cover ~50% of the electricity costs when averaged over the course of a year, which is a pretty good deal imo. There's always the issue of low energy production / high energy demand in the winter though. The current battery systems available definitely aren't capable of aleviating this issue yet.
The problem in Germany is that a lot of people live in apartments or older houses, where adding such systems is cost-prohibitive or not possible at all. In the apartment complex where I live, we have been trying to get a solar system approved for years without any success. That was before the invasion of Ukraine though. Maybe at our next condo association meeting we'll have more luck. I have a feeling the invasion will result in a lot of projects here being pushed through the approval phases more quickly. We need to be setting up wind mills everywhere possible, which is something that has previously been subject to lots of red tape.
pmv
15,142
10,044
Same for much of the UK. It's why I get irritated at those who push "micro solar" systems, and the idea of subsidising them - they are all very well for those who are wealthy enough to have large houses with lots of roof-space per person, plus the money for the initial capital outlay. In inner city areas people live in flats, and have very little roof-space per person.
Plus the freehold system means putting solar on such buildings would be the responsibility of the freeholder - the same freeholders who are extremely reluctant to pay out for even the removal of potentially lethal flammable cladding. Often the freeholder is the local council, who can take decades to get round to even basic repairs, there's no way I can see them getting their act together for things like heat pumps or solar panels.
Hence subsidising solar (through a levy on everyone else's fuel bill - the way they tend to want to do it) just works out as subsidising the already-well-off at the expense of poorer people.
(Can heat pumps be used on flats/apartments? I had the impression they needed plenty of land, but there are air-based versions, no? I don't know if those would be usable for apartments/flats? They seem to me to be like an Air Conditioner unit running backwards - is that basically it?)
Reactions: KompuKare
K1052
53,912
48,712
Air source heat pumps have been a thing for decades at least. You can get mini-split versions too which seems to be a more popular form factor for A/C in Europe from what I recall. People would stick them on roofs, balconies, or just hang on the side of the building. Heating performance used to kind of suck but in recent years there have been significant improvements.
Random example from Spain where they mostly seem to mount condensers on the building exterior
Zorba
15,613
11,256
The vast majority of heat pumps are air to air, just a normal AC ran backwards. It's literally the same equipment with a reversing valve installed.
They do lose their efficiency in environments below freezing or with a lot of moisture in the air.
Heat pumps should also be used in electric cars.
Reactions: hal2kilo
Zorba
15,613
11,256
The biggest issue with that setup is in heat mode you get condensation on the outdoor coil, which would drip on everything below of no drip pan was installed.
Reactions: cytg111 and K1052
hal2kilo
26,670
12,737
They even have heat pump dryers now. My electric company was pushing them with a deal last year.
pmv
15,142
10,044
I really don't understand any of this stuff. If heat-pumps are like AC, how do they help with energy conservation? AC is a big consumer of electricity, and here (and maybe for much of Europe?) that electricity tends to be produced from gas anyway. What's the big selling-point of heat pumps? If they take electricity to run, where's the saving?
Solar seems promising, but does it not require scarce mineral resources (that have to be dug out of the ground with corresponding environmental cost) to produce them, ergo would it not be more efficient to use those that exist in lower-latitude countries that get more sun? Or are solar panels much more widely available now than they used to be, so it's worth using them even at Northern latitudes?
(Also, could the same unit be used for AC in summer and run as a heat-pump in winter?)
Most of all though there seems a massive problem of inertia with actually getting housing stock improved, because of the complications of how ownership works. As I say, local councils are utterly hopeless at actually maintaining the housing stock they are responsible for, even when it costs them money in the long run to not do maintenance. Things like solar and heat pumps or even basic insulation seem likely to be entirely beyond their capacity to manage.
Fenixgoon
33,696
13,426
Electricity generation, even by gas, is still more energy-efficient than gas distribution and heating house-by-house.
Reactions: Brainonska511
pmv
15,142
10,044
That surprises me. I don't really know but generally had the impression that the opposite was the case. Certainly those who have to heat their homes with electric fires tend to have much, much, larger bills than if they had gas fire heating. Likewise electric cookers are more expensive to run than gas ones. Seems logical given that to use electricity for heating requires an additional stage, of conversion from gas to electric, at the power plants, and that's going to involve a loss of efficiency.
Unless the point is that a heat-pump uses much less electricity per joule of heat produced than, say, an electric fire? Because it's getting more heat out of the air (or ground) than it's using in electricity? And that this gain more than makes up for the waste of the conversion process at the power plant?
K1052
53,912
48,712
This is it precisely. Heat pumps are way way way more efficient than electric resistance heating.
[DHT]Osiris
17,575
16,955
Here you go, plenty of other comparison sites available.
pmv
15,142
10,044
Interesting. Heat pumps definitely seem worth investing in, on those figures. Though given the complications of how housing stock is managed and owned it really needs concerted action by government to ensure it actually happens.
I notice it also rates "wood burners" highly, but the problem with that is the massive amount of localised particulate pollution they create.
Surprised how well coal scores on a purely cost-basis - but I think the CO2 emissions are greater even than for gas.
hal2kilo
26,670
12,737
Also carves up eastern American hardwood forests. It's renewable you know. But, sustainable?
Atari2600
1,409
1,655
All well and good. But they kinda stop working <3 deg C.
The external Hx will freeze up any water vapour in the air and swiftly clog.
I suppose you could run heating elements though it to try and stop that, and accept the crap performance when its freezing - but not exactly the magic bullet many in the media purport.
Reactions: DaaQ
[DHT]Osiris
17,575
16,955
Wood burners are cheap/efficient for btu's, but yeah there's health concerns. Wood pellets are much better (we have one, love it). More efficient, and better for the environment.
[DHT]Osiris
17,575
16,955
They do? Our heat pump ran like a champ all winter.
Reactions: pcgeek11
dank69
37,649
33,381
You just reverse the cycle for a few minutes to thaw the condensation.
Reactions: pcgeek11 and Zorba
Dec 10, 2005
29,779
15,413
I feel like that is a pretty trivial problem to solve.
The TechnologyConnections guy points out that there are heat pumps that still retain good efficiency well below freezing. You could easily cover 95% of the year for many people in the US and Europe with existing heat pump technologies, and cover the rarer extremely cold day with some back-up traditional electric heating
repoman0
5,191
4,574
My heat pump system works just fine for heat 100% of the year in Boston * shrug *. It certainly draws more power the larger the delta T it has to overcome meaning it’s pretty expensive to run in the middle of the winter, but I haven’t found the lower limit yet. And it’s very cheap to cool the house in the summer since a comfortable temp difference is usually only 10-15 degrees F. Modern systems are very good and at this point I wouldn’t choose anything else.
Atari2600
1,409
1,655
So, I'd always been told that when temps approach freezing, the COP approaches 1.
Due to ice formation on the external Hx forcing either direct heating or reverse cycling (i.e. sucking heat out of your house to melt the ice).
Has anyone actually measured their power draw for summer vs. winter?
NutBucket
27,181
649
That's generally the rule of thumb. I've noticed modern heat pumps will usually have thermistors to measure outside air temp and coil temps so they cycle properly before freezing up.
I think there are more advanced units that can operate efficiently at even lower temps but I do not know what the differences are.
Zorba
15,613
11,256
It really depends on the amount of moisture in the air. Below freezing the air is generally pretty dry most days. As the coil freezes up and loses performance the system will reserve for a few minutes and generally kick on the aux heat to make the refrigerant hotter for the the ice melting.
I believe newer units have designed their coils to help prevent ice build up as well.
At the end of the day, you just lose some efficiency but not all of it. You also lose some efficiency as it gets colder out because there is less heat to move into the house. Just like AC loses efficiency as it gets hotter outside.
Reactions: dank69
Meghan54
11,684
5,228
Our 25 y.o. Trane heat pump does very well until it hits in the low 20's F. It has built-in resistance backup heating...labeled "emerg. heat."
Has a defrost cycle, too.
I'll deal with it being elect. in the winter vs. having gas...nice to have until it's not.
Reactions: iRONic
