calvinbiss
Give me your estimates for complete replacement of a 5 ton, 16 SEER heat pump system, including new compressor, new coils, new two sage blower, etc. on an existing house. Including labor.
$Eleventy Billion. Just send a cheque and I'll send a crew right over.
The wife doesn't like the heat pump. Our winters aren't very cold but you only get about a 20 degrees rise over the room temp as opposed to the 110+ temp from a gas pack. Unless the heat strips come on and then it's quite expensive.Is there any advantage to having a heat pump vs. AC and a gas furnace? Assuming the building already has provisions for gas, of course.
