I got an issue with heat right now.When i put full load on cpu i reach 64 c ( idle its 45c ) . Problem is , summer isnt even there yet and its still cool so i cant imagine what ill see when the hot days show up 🙁
Spec : Lian li v1100 case / p4 3.2 c with a zalman 7000 alcu running at max speed .
Should i change the Zalman ? Should i change those 120mm for better one ?
Im planning on adding an extra 120mm under cdrom so it create a better airflow over the cpu / rear exhaust .
Noise is important.
Any ideas or suggestion ?
Noise is important.
