ino uno soweno
Black,
This picture of the GT4 show the rear bumper and above bumper panel, ( below taillights) and wing have already been very quick sanded just to remove the major white flake to make it a bit more drivable,
Please also note, the hatch door flaking, parallel clear coat splitting / flaking top rear quarter, to the driver’s side door,
Some flaking on the roof channel,
Would you agree the GT4 was continually parked with it’s rear facing direct sunlight,
The next picture “from the opposite direction “
Shows no sanding marks or flaking on the front bar, which I will point out is in good condition, actually a beautiful clear deep coat, front guard has finger nail flake size where the guard meets the bonnet, I think they closed the bonnet on some tools, chip the paint to the metal ? but absolutely UV damage, no flaking of top coat on that guard, only slight accident damage at the rear of the wheel arch, and damage directly above wheel, caused by wheel when the car was very lowered, no flaking from sun or accident damage, please note in this picture the door has no flaking, the quarter has no flaking like the other side,
Next pic shows other mudguad also with some damage from the wheel from being too low, no flaking on this guard, clear coat is good, plenty of deep shine,
Facts , the rear of the car was exposed to direct sun light, bumper and upper panel flaking badly,
Fact,The front of the car was not exposed to same direct sunlight,
Fact, the clear coat flaked over the area of the turbo, as seen in the picture, was caused by the turbo, I never said JCH’s engine lid was going to flake, hello.
Now what you 2 have got wrong , well lets say this is only the first part of what you guys have got wrong is, go back to the start of the thread, and look for the words,
TIE-COAT, AND INTERCOAT PRIMER, AND or LINK COAT FAILED DUE TO 2 DIFFERENT sources OF HEAT,CAUSING THE GOOD CLEAR COAT TO CRACK THEN SPLIT, AND FLAKE,
The link coat caused the problem, ok, no fault of the clear coat, ok If I had applied the clear coat on this car I would not have needed a link coat, ok, well if you take the time to look at the front bar and guards, they are great, like you say, your clear coats are great, I believe you, a professional expensive clear coats are good, I agree, and add my experience, will last longer still without a non-speciation link coat, and a coat of new finish which contains no wax,
Back soon, you have a nice day.ok.
exOH, the above pics were after I removed the bad flaky top coat, the flaky bonnet pics was taken before that, and here is a recent pic,
