HDTV / progressive scan question
her209
56,336
11
Originally posted by: RaynorWolfcastle
Originally posted by: Finalnight
Audio:
SPDIF(COAX)>Toslink>Surround RCA>Stereo RCA>Mono RCA>Mono Coaxial (F)>Crappy little screw connectors from 80's
Can somebody please explain to me why people say SPDIF coax is better than SPDIF optical? Digital is digital, as long as there are no errors in the data transmission I could send it by telegraph or by pigeon if I wanted and it should work in exactly the same way.
Someone please explain this to me, I'm dying to understand what this is based on.
Bandwidth limitation maybe?
MustISO
12
Audio:
I think it's all a matter of opinion. The same way people say $200 speaker cables are much better than $20. Could *I* tell the difference probably not. Some people claim they can hear a difference between coax and optical. Optical is not effected by RF, so for people who have an issue with signal leak it may work better. The coax could act as an antenna whereas the optical would not.
CFster
1,903
Audio:
There isn't a difference signal wise. However, TOSLink cables are by nature fragile, bend one a little too much and it's toast. I think that gives COAX a slight edge.
CraigRT
31,440
component video is a must.
you can turn the prog. scan on and off on my DVD player and see the difference on the screen immediately. I like the way it looks with prog. scan on better.
people say my TV has a crappy de-interlacer :p
it's a Panasonic 47" HDTV
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
CraigRT - Where did you buy your Panasonic from and which model is it?
spidey07
65,469
DVI IS NOT > Component
It totally depends on the TV. In his case he is using an analog TV...in which case component "should" give a better picture depending on the TVs internals.
On a digital display DVI is better. But normally not on an analog set like the s500.
Apex
6,511
www.gotapex.com
Just because a TV is analog (CRT's) does not mean component will give you a better picture than digital. With DVI you're still skipping one digital-analog conversion. The only blanket statement that can be made is an analog set will tend to exhibit less of an improvement, and in fact sometimes unnoticable, with the use of DVI over component.
spidey07
65,469
totally depends on the entire system. I'm sure you realize that there can be no blanket statement. With many analog TVs component does indeed produce a better picture than DVI. Depends on the TV and how it routes the signal. Some even send the DVI input through another digital-analog-digital-analog conversion and component is just analog-digital-analog.
go figure.
Apex
6,511
www.gotapex.com
go figure.
Ouch man, that's horrible. What a way to design things. Which TV's do that D-A-D-A conversion?
slag
10,473
DVI interface is *ALWAYS* better than component because DVI is totally lossless and has full bandwidth to pass the video signal without any loss.
How the TV or monitor implements the DVI interface is another ballgame, but DVI as signal transfer medium is ALWAYS going to be better than component.
Always.
V00DOO
3,817
Nice TV. I have the same TV. Like every said you have to use the component cables or DVI (the 51S500 does have DVI) to have progressive scan. You can set your Virtual HD to either 540P or 1080I. Personal, I perferred the 1080I. Don't waste you money on Monster Cable, just get some AR components cables from you local Best Buy under $30. Currently, I have my 51S500 connected to Directv HD via DVI and the HD picture looks awesome. I just wish more HD progammings are available.
Apex
6,511
www.gotapex.com
Originally posted by: V00DOOCurrently, I have my 51S500 connected to Directv HD via DVI and the HD picture looks awesome. I just wish more HD progammings are available.
More HD programming is available It's called Voom. ;)
