HDTV indoor Antenna ANT1500 - $32 free shipping
coffeecandy
9
Google Coat Hanger Antenna for the instructions on building it
Then this is the link for the reviews and opinions at high definition forum http://www.highdefforum.com/lo...at-hanger-antenna.html
If you are getting a free $40.00 Digital Receiver and are deciding to build one the coat hanger antenna then I suggest getting a Balun Transformer (VHF/UHF transformer) from http://www.summitsource.com/ for 39 cents + S&H. S&H is about 8 dollars from summit source if you live on the west coast. Summit source does take the 40 dollar coupons and offers digital receivers.
Radio Shack sells these balun transformers for 5 dollars. So 8 dollars for shipping for a balun transformer and a Free Digital Receiver is great.
High Def forum also has suggestions for Over the Air (OTA) reception and which Antennas to purchase and one of them is NOT to buy a Radio Shack Antenna. There are better brands and better Makes.
quadomatic
993
Originally posted by: Scarpozzi
I've been using this one for the past few months and love it.
Free is always better...well it's always cheaper anyways.
OTA HDTV is great. As long as you have at least a 60% signal, it'll play great, and look fine. No snow on digital.
mrdeucie
31
I tried one out in NYC (Manhattan) in an apartment on the 4th floor out of 12. It did not fair well, but I also don't have any windows facing the Empire State Building.
VaG
1,324
Originally posted by: quadomatic
If you need an antenna, don't buy one. BUILD ONE!
I went through a few antennas at radioshack, and none of them worked well. Then I found that with a piece of wood, a few coat hangers, screws and washers, and a transformer for coaxial connection to the antenna, you can build a DAMN good antenna. It only costs about $5 for the connector. Everything else you'll probably have lying around. I got a piece of wood at Home Depot for $3 or so. I'm never going back there though...I waited in checkout for 20 minutes for them to price the wood.
Aiming the antenna can be an issue, but that'd be an issue with any HDTV antenna.
Here are some pics:
http://img299.imageshack.us/img299/3058/img1679ph4.jpg
http://img184.imageshack.us/im.../158/img1680aq7zg9.jpg
I don't mean to dump on the deal though!!! It seems like a nice deal.
Just offering a suggestion
Do you have any images of your new TV sitting on top of your old TV?
