Originally posted by: pontifex
i thought the 120hz was supposed to be a good thing?
didn't find a way to turn off 120 hz, but i think i found the culprit. there is a Real Cinema Mode setting. If I turn that off, everything is fine. The manual describes it as a feature to improve image quality. guess it doesn't quite work as intended.
It has 2 settings, smooth and precision. With either one on, it causes the effect i mentioned.
Originally posted by: rh71
Looking for something in the same ~$600 range for my parents... it looks like the OP went with a $1k set? I'm wondering if a 720p (1080i) Vizio unit would be just fine and the only reason to go 1080p would be for Blu-Ray discs. They'd be watching typical HDTV (from cable). 720p is pretty future-proof still?
http://www.walmart.com/catalog....do?product_id=8477432 vs. http://www.walmart.com/Vizio-3...-HDTV-VW37L/ip/5684931 worth the extra $90?
