That's pretty much the benefit, less cable space. And better audio input if you make use of that.Originally posted by: yowolabi
I just switched from component cables to a hdmi cable. I watched the same scene multiple times with each, even paused it and zoomed in.... i couldn't notice a difference once i made the settings for each input identical (contrast, brightness, etc.). So i'm using the hdmi cable since it takes the place of 4 or 5 cables, and since the hdmi slot would go unused otherwise.
*However*, with my dlp set, having my tv upscale from 480i to 1080p from an hdmi cable looks much better than the same upscaling from component cables. Pretty much the same deal with vga & dvi connections to monitors, native resolutions are difficult to tell any difference, but non-native resolutions and the digital connection looks better.
