HDTV Gurus: Big difference between component cables and HDMI?
Danman
13,134
Alright guys, I just got my HD DVR box hooked up with component cables. Running 1080i, looks freakin amazing. I do have HDMI output on the DVR box, and my TV has DVI in.
Would an HDMI to DVI cable make a huge difference over component cables? Obivously, I would have to buy this to try it out...but I wanted to see what you guys thought of it first. Thanks! :)
-Dan
Allanv
905
I went with component instead of hdmi -> hdmi because it looked better. Stick with what you have
GoingUp
16,720
I used HDMI. Its digital, so thats the one I'd go with.
Plus it can also transport sound.
paulxcook
4,277
I think they both look good, but technically i think hdmi might be a bit better, plus it handles video and sound in one cable.
Linflas
15,395
78
I really haven't noticed any difference for anything other than my DVD player. The only reason it made a difference with the DVD is bcause the upscale only works over HDMI.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Component looks a bit warmer to me on my DLP... and warmer is what i prefer :)
yowolabi
4,183
-Dan
I just switched from component cables to a hdmi cable. I watched the same scene multiple times with each, even paused it and zoomed in.... i couldn't notice a difference once i made the settings for each input identical (contrast, brightness, etc.). So i'm using the hdmi cable since it takes the place of 4 or 5 cables, and since the hdmi slot would go unused otherwise.
sdifox
100,450
17,947
Originally posted by: Shawn
HDMI should definitely look better.
Theoretically true, but in real life, theoretical are useless. If you are not using a huge tv nor pulling your component cable through the middle of a MRI machine, you can't tell the diff.
gerwen
312
As already said, difference will be minimal if noticeable at all. Depends on the device/tv combo as to which is better.
Stick with your component cables.
hanoverphist
9,867
23
just realized if i switched to hdmi i could put my ps2 on component! hehe thanks for the reminder.
NaOH
5,015
If it wasn't for that fact, I would go with whatever is cheaper/in my possession already.
paulxcook
4,277
There are component upscalers out there. Zenith has one, I think Oppo does too. They've been discontinued, but can be found on ebay. Upscaling + no DRM = win.
mercanucaribe
Banned
Oct 20, 2004
9,763
Why do some people on this forum love upscaling DVD players so much? You know it doesn't actually make the video higher resolution right?
Linflas
15,395
78
I don't necesarily love it but it is a feature built into my DVD player and I make use of it. It does make the picture look better than it would otherwise look and I don't plan on wasting my money betting on which of 2 incompatible formats both with crippling DRM built into them will win the silly format war that HD-DVD and Blu-Ray are waging.
lightpants
2,452
It will not transport sound into his DVI input.
