- May 19, 2011
- 21,623
- 16,900
- 136
I built a computer for a customer (socket 1200 gen) and its board only has HDMI and DisplayPort outputs. The customer has a monitor with a DVI socket on, and I naturally thought I could use a HDMI to DVI cable to connect the two. It didn't work, the monitor reported no signal through the cable.
Luckily I had a DVI -> HDMI adapter and a spare DVI cable which worked. I had two theories going forward, one was that I have a faulty cable, and the other is that I think I saw somewhere such a cable being sold but with a warning that it would only work a specific way around. I didn't buy that cable, but I was wondering whether there's more going on what with HDMI/HDCP etc and even though DVI and HDMI are quite similar, perhaps there are these little swings and roundabouts to be encountered occasionally.
I just tried the cable on a monitor at home and another computer I've built with the same board as the first and the cable works fine.
The only other difference I'm aware of between the cable I ended up using for that customer and this one is that the one that worked was a DVI single-link cable and this cable is a dual-link type. I wonder whether the customer's monitor didn't like the dual-link nature of the cable?
Are there any further complications in using DVI-HDMI cables that I ought to be aware of?
