LoveMachine
Greetings, I have a general use/HTPC computer with the components in my sig (take note that the video card is the HIS iSilence 7750). Everything works dandy (1080p movies/DTS sound, games, general computing) using WMC, XBMC, iTunes, except for one niggly stoopid problem. In Windows Media Center, movies play fine, but Recorded TV shows from OTA TV tuner do not play correctly (Live TV works no problem). Select the program, and video plays for a few seconds without audio, then an error message comes up saying "Video Error: Cannot play video because drivers are missing. Restart Media Center or your computer". With a restart, same problem. When using Windows Media PLAYER, the files play just fine. The problem only happens when watching the show when my Onkyo 708 receiver is on (which then feeds my Panasonic TV). All this is connected via HDMI. With the receiver off, just using my LCD Samsung monitor connected via DVI, WMC plays the file fine. As an experiment, while in WMC, I unplugged the HDMI cable going to the receiver and plugged it back in. The files then play just fine, and continue to do so unless WMC is closed and restarted.
Currently running 12.8 CCC, downgrading to 12.6 and running driver sweeper doesn't change anything. The receiver and TV are running the latest firmware available.
Since everything works perfectly when resetting the HDMI connection, I'm convinced this is an HDMI handshake issue. Also, since all other media play in all other players, I wouldn't think it's any other sort of hardware issue. After scouring the Egg's product reviews of the 77X0 series and finding nothing similar, it's unlikely a general driver problem.
Anyone have any thoughts on my line of reasoning? Any suggestions on possible fixes (other than constantly unplug/plugging the HDMI cable)?
MediaInfo dump of a sample file in question:
General
Complete name : F:\Recorded TV\Nature_KOPBDT_2012_08_29_20_59_00.wtv
Format : MPEG Video
Format version : Version 2
File size : 5.40 GiB
Duration : 1h 0mn
Overall bit rate mode : Variable
Overall bit rate : 12.7 Mbps
Video
Format : MPEG Video
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Duration : 1h 0mn
Bit rate mode : Variable
Bit rate : 12.7 Mbps
Maximum bit rate : 65.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.204
Stream size : 5.40 GiB (100%)
Text #1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Stream size : 0.00 Byte (0%) __________________
General
Format : MPEG Video
Duration : 1h 0mn
Video
Format : MPEG Video
Duration : 1h 0mn
Color space : YUV
Bit depth : 8 bits
Text #1
Format : EIA-608
Text #2
Format : EIA-708
