Is it okay to put hard drives in adjacent internal drive bays?
My case is poorly ventilated around the drive cage area. The internal drive bays set the drives apart by about 2-3mm, they're essentially right on top of each other. The drives are 60GB 75GXP's. Will heat be an issue?
I also have two 15GB 75GXP's in the same system, would it be better to place those next to each other instead?
