HD LED stays on?
wluk
Guest
Feb 2, 2001
1,676
Hi, I just bought an Antec 1030 to replace my old case w/ a dead PSU. Now the Hard Drive LED stays on all the time no blink at all? I am sure I have the right pin/jumper for the wire. What could be the problem? Thanks for your input.
wluk
Guest
Feb 2, 2001
1,676
i tried already. if i reverse it, the LED will no light at all.
Thanks for your input ukDave. I just rated you.
MichaelD
31,528
Make sure the HDD LED connector that goes from the front panel of the case to the motherboard is on correctly. I.E. facing the right way. Different mobos have different pin/connector orientations. This has happened to me. Turn the connector around.
Scootin159
3,650
Also make sure you do have it plugged into the correct pins (and not the power ones or something like that).
