I have two HD related problems/questions:
I installed a new HD on my comp (mostly stock DELL). I replaced my master boot drive (on the primary channel). For some reason, when I start my comp the computer doesn't initially find the drive. I receive the following error: "Primary Drive 1 Not Found." I forget the exact verbage but is says this for channel 1 and 2. I am presented with the options of continuing or entering setup. If I continue, the computer starts as one would expect.
Second Question:
I moved a slave drive from the primary IDE channel to the seocndary IDE channel. This channel is currently attached to a 40 wire connector (vs an 80 on the primary). Should I have problems mounting the existing partition on this drive? What would be the best setup? It is a slave to the CD-ROM on the secondary channel. Can I replace the 40 wire with an 80 wire?
Thanks
Second Question:
Thanks
