HD 7850 Voltage Lock
p_monks33
Ok, so I have tried 2 different cards in my HTPC and cannot control GPU voltage on either card, so I am beginning to wonder if my MB wont allow GPU voltage adjustments. Specs: P8H61-I R.2.0 with an I3 2125, 8GB Corsair 1600 Ram, And an MSI TF3 Non OC 7850, all running on a Silverstone 450w PSU. I tried to unlock voltage on a 7770 as well and thought that maybe it was the card, but now 2 cards in a row has me wondering if it is my board. I have tried drivers all the way from 12.6 to the most current 12.11, Tried afterburner 2.2 , 2.3, 2.5 , With the EULA and without, I make sure to check unlock voltage. The voltage block is just blank and the slider is all the way to the left. I have tried Trixx , and GPU Tweak. No voltage in either of those. I am stumped and feel that it must be my motherboard holding me back from a good overclock. Please anyone with advice chime in.
I found that I had to flash my cards to different brands in order to unlock voltage. The Asus and MSI roms worked the best. I think techpowerup has a bios database that you can use.
Thanks Sickbeast, I tried a flash on the 7770 that the MSI tech rep sent me, it had no effect. Its really eating at me that I have a card that is known for overclocking and I cant do jack squat to the voltage to get the most out of it.
You are using wrong versions of MSI AB that don't include the 2 missing .dll files. No versions after 2.2.1 will work since they don't include the 2 missing dll files and no Catalysts after 12.4 I believe include them either. This is why it's not working for you.
1. Before you do anything, go to your MSI Afterburner main folder:
C: \Program Files (x86)\MSI Afterburner
Do you have these 2 files in this folder?
atipdl64.dll
atipdlxx.dll
If you do not have these 2 files, you need to download them and paste them into the main MSI Afterburner folder. The easier solution is just download MSI Afterburner 2.2.1, install it. This program includes the 2 missing dll files by default. If you wish to use newer MSI AB versions after, you can extract them and repaste them into newer MSI AB versions. For now though just use MSI AB 2.2.1 to get it to work and later you can re-install to a newer version.
2. The next step is for you to find the MSIAfterburner.cfg file in the main MSI Afterburner folder. Take this file, cut it and paste it onto the desktop. Right click it, Open with ... Notepad.
Drop 2 lines under the heading [ATIADLHAL]
UnofficialOverclockingMode=1
UnofficialOverclockingEULA=I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
File --> Save As --> Override the .cfg file when it asks you. Now take this file, and make sure it's still called MSIAfterburner.cfg, and paste it back into the main MSI Afterburner folder where you already have the two .dll files I outlined above.
3. Download Asus GPU Tweak (should be able to find it in Search on Asus.com website). Once you open this program, go to Settings --> Tuning --> Tune Settings --> check mark "Overclocking range enhancement", press Apply. The screen should flash black. Now you can close Asus GPU Tweak as you don't need it again. You can go into the Main menu and disable this program from starting on boot.
Restart the computer. Now open MSI Afterburner and the GPU voltage and all the overclocking sliders for GPU core and memory should be unlocked.
You can also try unofficial overclock mode 2 to see if that helps. Also try Asus GPU Tweak. I had the best success with that program and an Asus BIOS.
Tried all the above, couldn't get voltage control in afterburner still, I can use it in GPU Tweak, but theres no reason too because it only goes too 1050 core which I can hit stock voltage no problems. Oh well, I will just be happy with what I got.
Go into the advanced options and unlock the higher clock frequencies. It should work perfect.
whats the max voltage it allows please? id like to know
1.225 I can get it up to 1200 core on that voltage. I see no reason to go higher. Im set at 1100 for added stability. No good for much other than benchmarking
Hate to sound like i got my tin foiled hat on Russiansensation,but do you got another source to download the older 2.2.1 msi afterburner ?
I downloaded the source file you linked in a above post which came from msi itself and those 2 files are still missing in that folder,almost as if they took them out,looking forward to overclocking a 7970 i will be buying soon.
Been voltage locked out of my msi tf3 7850 since i switched out my hard drive for a ssd and did a fresh format,none of the ocing programs period unlock it.
Anyone have another source for 2.2.1 afterburner besides msi,i seriously think they deleted those files off the hosted file on purpose so i think a third party site could have a unedited file?
Can you go beyond 1.225v with these cards?
I luckily got a decent clocker, but I think I could go further with a tiny bit more. (I'd like to be able to do 1.24v, which Asus told me was safe when I had the Asus card, which would allow up to 1.3v. My sapphire card won't go past 1.225v no matter what I try, so assuming its some sort of bios lock. I'm at 1225 core @ 1.225v.
Mine only unlocked to 1.225v as well,that was when it did unlock but heck every version of msi afterburner,gpu tweak and every known run around now won't unlock my card.:awe:
Kinda actually pissing me off as the card really doesn't oc to well only hitting 1050/1450 and now some hidden issue obviously is jerking with me an on stock voltage it hits stock clocks,a 20mhz increase on the core and it artifacts.
What driver version you using anyways?Using 12.11 beta 8 here.
I gave up, and just settled with the fact im not gonna overclock via afterburner. I hit 1200 core 1600 memory via Asus GPU Tweak and decided for everyday gaming 1.225v to hit 1200 is kind of dumb. I am at 1125c 1450 memory on 1.15v and cant tell much difference between FPS in the two. Maybe 1-2 frames at most.
Same here - 12.11 Beta 8
I've been running at 1225/1325 @ 1.225v for 2-3 weeks now without issue
Here is a 3DMARK11 Score
http://www.3dmark.com/3dm11/4964685
Driver listed as unsupported due to using the beta
I guess if you are just benchmarking then the added voltage would be nice, but for everyday gaming, I cant tell the difference in 1050 core and 1250 core, 5 Fps just isn't that noticeable too me I guess. Plus I am in a tiny case that is jammed full of stuff so I don't want unnecessary heat without major gains. Bigystyle are you just trying to max out a bench or are you actually needing the extra clock speed for something game wise?
Nope
Just tinkering. Always like to see how far I can push things
Finally figured out how to reenable voltage control,it was a major pita.
Slapped the missing dll files into the amd driver folder,deleted the msi ab folder then after i had the latest version of gpu tweak open,this part was the kicker but when i disabled the skin under the main tab under settings and applied it as such,all of a sudden gpu tweak automatically enables the 1.225v core and i hit apply and save as profile 1.
:awe:
A reboot and a few adjustments and i'm smooth sailing at 1050/1450 as before but nothing under the sun would get msi ab to work period.:|
Seriously needed that oc as i just purchased a Dell u2412m to replace a old 17'' 1440x900 monitor......Anticipating BF3 is gonna every mhz the 7850 can deliver till i purchase a new 7970 anyways.:biggrin: Sucks i could not afford both at the same time and took hours before i made up my mind which i was gonna get first.:awe:
Beautiful overclock you got there.
My card simply refuses to really oc pass 1050/1450 but honestly coming from 900 preoverclocked,and all the way from 860 default bin,the oc headroom is much better then anything of recent years i believe.
Thanks.
I buy a lot of cards, I'm always flipping them locally, I do lose a little $ but its a hobby I enjoy. I prefer to game on a big screen, and even though I own 3 big screens, my favorite TV is my 6 year old Plasma thats only 1360x768, so its more than enough powerful for what I need.
This is the 3rd 7850 I've had. This card's Core clocks very well, Memory not so much. I seem to get issues at 1350 and 1375, so I just left it at 1325 since Core O/C's are more important on these cards.
I had an Asus card that would do 1310/1450, but also had a 2nd Asus 7850 that would only do 1150 Core.
1050 will still be a really nice boost.
Thanks.
Yeah,for 1440x900 this 7850 has been excellent but BF3 still in some maps and spots could dip into the low 50s and sometimes the 40s rarely but some maps like Metro simply refuse to dip under 60 fps bare minimum maxed out,just maps like oman and some heavy spots in Caspian when i find the dips.
Gonna be giving my gf the 7850 as i aim to build her a tower right after i purchase a 7970,for her games its gonna be overkill so most likely will undervolt it,match it with a i3 and it will be pretty peachy.:biggrin:
