edplayer
When I forceably massively overclocked my 5770 it used nearly 300w. Pumping up both voltage and maxing out processor and ram speed pushed way beyond catalyst settings.. with max CCC clocks at high durations it pulled 200-225w peak after a hour or so of gaming and when cold it pulls mid 170w type draws at full load if your gaming for less then 60 minutes. As tempautres went up over time it started drawing more current. Typically BTW of silicon devices.
I verified this with a amp probe twice.
Your mileage may vary and I declocked and put stock cooling back on. I just didn't need the extra performance right now. But it was fun to tinker.
idle consumption was always good unless way overclocked. 18-20w idle and with stock settings it peaked for power useage around 150w or so. Using the catalyst panel you can push consumption up. to just over 200w.
I really don't care what people have published. this is with a refrence card design hd5770 that I have in my hand and use dialy.
Get a big power supply and a good one.If you plan to run the card at stock settings 550w Ps will be plenty. If you plan to overclock and overvoltage get a big power supply.
Maybe you know a lot about electronics so,
What do you think of the methods they use at Xbitlabs to test videocard power consumption? Look here:
http://www.xbitlabs.com/articles/video/display/gpu-power-consumption-2010_2.html
To me it seemed like the most advanced test (just for power use) of all the hardware sites that I view. And what do you think of their numbers for the 5770? I think it used sub 80 watts for Crysis. Most other review sites will measure the whole system at the wall (I assume with a kill a watt or a Brand 1850) and also get results around 80 watts. Are they all wrong and if so, do you know why they are all getting low results?
This is because you say a stock 5770 will peak around 150 watts
