- Jun 17, 2005
- 2
- 0
- 0
New to the forum. I'm hoping someone can help me out.
I'm running an A8N-SLI Deluxe mobo with 2x512 OCZ PC3200 memory sticks. Specs:
Model:
Brand: OCZ
Series: Enhanced Latency
Model: OCZ4001024ELDC-K
Type: 184-Pin DDR SDRAM
Tech Spec:
Capacity: 1GB (2 x 512MB)
Speed: DDR 400 (PC 3200)
Cas Latency: 2
Timing: 2-3-2-6
Voltage: 2.6V
ECC: No
Registered/Unbuffered: Unbuffered
Its been running fine for 3-4 months since I built the system.
I just bought a 1gb stick. Specs:
Model:
Brand: OCZ
Series: Enhanced Latency Platinum Series
Model: OCZ4001024ELPE
Tech Spec:
Capacity: 1GB
Cas Latency: 2
Timing: 2-3-2-5
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
Features: Mirrored Platinum Heatspreader
I'm having a problem getting all 2gb to register. I updated the BIOS to the newest version. I've tried each stick individually to determine if 1 of them are bad and they all work ok. I've tried every combination of slots and the best I can get is 1-1/2gb.
Does anybody have any idea of what it could be before I decide to send this memory back?
Thanks!
Chris
Model:
Brand: OCZ
Tech Spec:
Cas Latency: 2
Timing: 2-3-2-6
Voltage: 2.6V
ECC: No
Model:
Brand: OCZ
Tech Spec:
Capacity: 1GB
Cas Latency: 2
Timing: 2-3-2-5
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
Thanks!
Chris
