Having problems with Plex Media Center
Greenlepricon
So I got my HTPC with 64bit Windows up and running, but am having trouble trying out Plex. Everything downloaded alright, but when I try to run it, the program ends up having incomplete text. I can scroll up and down like you are supposed to, but everything is illegible and will not run correctly.I have tried uninstalling and redownloading it several times, but it always has this problem. Does anyone know how to fix this? If not I'll just use a different media center, but I was looking forward to trying this one.
Nope mine works and never had that problem.
Try uninstalling it with a heavy root remover uninstaller and delete all the left over folders before reinstalling
Ok will do. I haven't had time to work with it but I'm going to try a torrent or something if it doesn't work
