Uncore is matching my CPU clock... so 4.4 Ghz at the moment. Memory is untouched from stock (10-10-10-27 1600 @ 1.5V). Vin is 1.2V, Vcore is .896V.
Drop your uncore back to 38, set it manually.
Work your core first, otherwise try bumping your uncore voltage but it's a hassle to try to figure out which is causing the problem so focus on one aspect (core) then move to the next (imo).
Try backing down the voltage, to say 1.25v also turn off LLC it's pretty much worthless now with the voltage regulators on the die.
Kind of dismayed how immature the bios's are, and that's from all the vendors.
I have no "uncore" setting, but there is a CPU cache ratio. I set it to 38 manually, it still crashes at 4.5 GHz. This is with 1.32V on CPU voltage, 1.9V voltage input, highest load-line calibration.
Is this just the limit of the silicon??
Cache ratio should match CPU multiplier. I think Uncore is cache ratio. Some bios' state it differently.
Highest RAM Frequency Reached :
- Nº 1 : Nick + John @ HKEPC OC Lab reached 2172.7 MHz with 4096 MB of Team Group Inc. Memory [Details]
MB : ASRock Z87M OC Formula (Intel Haswell rev 06) - CPU : Intel Core i7 4770K @ 1241.55 MHz- Nº 2 : Lin222 + Planet + Nickshih @ Computex reached 2145.2 MHz with 4096 MB of Corsair Memory [Details]
MB : ASRock Z87M OC Formula (Intel Haswell rev 06) - CPU : Intel Core i7 4770K @ 1170.04 MHz- Nº 3 : G.Skill OC Show @ Computex 2013 reached 2144.6 MHz with 4096 MB of G.Skill Memory [Details]
MB : Asus MAXIMUS VI IMPACT (Intel Haswell rev 06) - CPU : Intel Core i7 4770K @ 1608.34 MHz- Nº 4 : G.SKILL COMPUTEX 2013 reached 2141.6 MHz with 4096 MB of G.Skill Memory [Details]
MB : Asus MAXIMUS VI IMPACT (Intel Haswell rev 06) - CPU : Intel Core i7 4770K @ 1606.09 MHz- Nº 5 : Andre Yang reached 2105.1 MHz with 4096 MB of Avexir Memory [Details]
MB : Asus MAXIMUS VI IMPACT (Intel Haswell rev 06) - CPU : Intel Core i7 4770K @ 2152.85 MHz
I have my 4770k @ 4.4 and 1.26v, I would like to get it a bit more lower on v core, I have it set manual vcore.. I think that adaptive would be better but I cant get it stable on it. Is there a setting that I can try ?
Edit: Just look at the speed difference between a 5.1GHz i7-2600k, and my chip at 4.7GHz Uncore (cache ratio).
http://farm8.staticflickr.com/7454/9080057869_74beb2fac0_o.png
I'm not even sure if it's reading it right, there is just a stupid amount of bandwidth there.
Dark Knight 2 with two static pressure corsair fans in push/pull.
Yeah I saw that 🙁
Can you use http://www.mediafire.com/?zp28fy8ru48x7r6 (cpuz 1.64.3) so I can see your actual voltage, unless that is what you set in bios.
What were your temps at stock? And is your board running 3.4 stock or 3.8?
this difference is software related, you need to use the same version of Aida.
The reason people are seeing "more stable" at lower uncore is because Prime95 is bottlenecked by cache speed when using AVX instructions (The whole reason Haswell has a huge cache throughput to start with).
Not overclocking the cache with the core means you are just gimping Prime95 performance, which is why you have lower temps. You get the same effect if you just let the chip thermally throttle.
It's not magic folks.
Read the Prime95 forum from the developers to get an in-depth technical analysis on this whole issue.
They have a nice thread on this.
Huh? Nobody is saying don't overclock the uncore, though a case can easily be made to just ignore it.
Can you link this thread you're referencing, I couldn't find it with google.
Who cares about the performance of prime95? Lower temps for me were due to cooler ambient and have nothing to do with cache ratio or bottlenecking AVX from what I have seen. Same effect as what? The only thing shown in here with prime95 was 4.8GHz core 4.7GHz UNcore and the temps were no different than AIDA64.
Evidently Prime95 is since it's so fast other linpack avx code doesn't suffer the same amazing performance crippling effect. I can't even begin imagine the amount of heat and power Prime95 would use if unthering it's performance was from the uncore bottleneck, considering it isn't any hotter than ADIA64 or IBT even though both run AVX code paths!
I'd love to read it, though I'm not sure the relevance. I couldn't find it with google though, could you link it?
Here is what I have:
4.8GHz core 3.8GHz Uncore - Hottest core 88C - Fastest time 129 GFLOPs
4.8GHz core 4.6GHz Uncore - Hottest core 88C - Fastest time 130 GFLOPs
Here is the gist of it for small length ones (specifically the ones that don't directly benefit from AVX2's increased bit length processing ability)
+40% on legacy (SSE2) code due entirely to increased bandwidth.
http://www.mersenneforum.org/showpost.php?p=343718&postcount=131
If you make it exactly 256-bit obviously you get the hilarious huge yields that a purely synthetic (Non-dependent) benchmark would give you.
Thats a huge increase purely from increased bandwidth.
=================== Timing linear equation system solver ===================
Size LDA Align. Time(s) GFlops Residual Residual(norm) Check
1000 1000 4 0.026 26.0931 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.008 83.1892 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.008 85.3023 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.008 86.6677 1.002198e-012 3.417754e-002 pass
2000 2000 4 0.048 112.1212 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.050 106.2897 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.061 87.4023 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.049 109.7069 4.327261e-012 3.764187e-002 pass
3000 3000 4 0.140 128.7982 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.176 102.2257 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.140 128.6445 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.140 129.1520 9.653528e-012 3.717342e-002 pass
4000 4000 4 0.314 135.8601 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.313 136.2905 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.312 136.9157 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.311 137.1751 1.565487e-011 3.412126e-002 pass
5000 5000 4 0.590 141.2435 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.592 140.8687 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.590 141.3670 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.592 140.9005 2.512907e-011 3.504046e-002 pass
10000 10000 4 4.280 155.7971 1.012627e-010 3.570624e-002 pass
10000 10000 4 4.275 155.9875 1.012627e-010 3.570624e-002 pass
15000 15000 4 15.932 141.2575 1.979849e-010 3.118294e-002 pass
15000 15000 4 16.082 139.9325 1.979849e-010 3.118294e-002 pass
20000 20000 4 32.094 166.2039 3.564028e-010 3.154945e-002 pass
20000 20000 4 32.116 166.0878 3.564028e-010 3.154945e-002 pass
25000 25000 4 63.792 163.3114 6.220813e-010 3.537553e-002 pass
25000 25000 4 64.971 160.3481 6.220813e-010 3.537553e-002 pass
30000 30000 4 117.158 153.6544 9.270371e-010 3.654390e-002 pass
1000 1000 4 0.027 24.4817 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 116.9661 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 113.6987 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 115.8336 1.002198e-012 3.417754e-002 pass
2000 2000 4 0.035 150.8695 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.035 151.3860 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.034 155.2040 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.036 149.4019 4.327261e-012 3.764187e-002 pass
3000 3000 4 0.104 173.0388 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.107 167.7035 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.104 173.6963 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.103 174.1454 9.653528e-012 3.717342e-002 pass
4000 4000 4 0.229 186.4405 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.231 184.9304 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.229 186.1771 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.229 186.1232 1.565487e-011 3.412126e-002 pass
5000 5000 4 0.433 192.4411 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.434 192.2064 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.433 192.6871 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.434 192.0620 2.512907e-011 3.504046e-002 pass
10000 10000 4 3.169 210.4104 2.977802e-008 1.050003e+001 FAIL
10000 10000 4 3.158 211.1710 9.805032e-011 3.457353e-002 pass
1000 1000 4 0.032 21.0860 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 112.8623 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 114.3003 1.002198e-012 3.417754e-002 pass
1000 1000 4 0.006 114.0276 1.002198e-012 3.417754e-002 pass
2000 2000 4 0.042 128.4695 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.036 149.8790 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.036 148.4749 4.327261e-012 3.764187e-002 pass
2000 2000 4 0.050 106.6145 4.327261e-012 3.764187e-002 pass
3000 3000 4 0.107 167.7921 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.108 167.2586 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.107 167.7909 9.653528e-012 3.717342e-002 pass
3000 3000 4 0.109 165.8319 9.653528e-012 3.717342e-002 pass
4000 4000 4 0.236 181.2239 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.235 181.8316 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.238 179.4995 1.565487e-011 3.412126e-002 pass
4000 4000 4 0.237 179.8140 1.565487e-011 3.412126e-002 pass
5000 5000 4 0.446 186.8200 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.445 187.3511 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.445 187.2766 2.512907e-011 3.504046e-002 pass
5000 5000 4 0.444 187.6106 2.512907e-011 3.504046e-002 pass
10000 10000 4 3.313 201.2619 1.012627e-010 3.570624e-002 pass
10000 10000 4 3.233 206.2836 1.012627e-010 3.570624e-002 pass
15000 15000 4 11.923 188.7423 1.979849e-010 3.118294e-002 pass
15000 15000 4 11.838 190.1115 1.979849e-010 3.118294e-002 pass
20000 20000 4 24.219 220.2491 3.564028e-010 3.154945e-002 pass
Maybe I'm too tired, but I'm not even really sure what we're discussing!
Anyways, I'm not even sure what to think. It's pretty clear the IBT linpack isn't hitting Haswell the way it could be, neither is anything else really. So what I'm guessing is that you are saying these stress tests we're using which were designed for older systems aren't optimized for Haswell, or perhaps even older uarchs and that we're kidding ourselves?
At least that's what I'm thinking, I ran the latest Intel linpack.. Jesus H Christ.
Stock: (Kept opening the file to make sure it was doing something, ops)
Code:=================== Timing linear equation system solver =================== Size LDA Align. Time(s) GFlops Residual Residual(norm) Check 1000 1000 4 0.026 26.0931 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.008 83.1892 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.008 85.3023 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.008 86.6677 1.002198e-012 3.417754e-002 pass 2000 2000 4 0.048 112.1212 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.050 106.2897 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.061 87.4023 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.049 109.7069 4.327261e-012 3.764187e-002 pass 3000 3000 4 0.140 128.7982 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.176 102.2257 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.140 128.6445 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.140 129.1520 9.653528e-012 3.717342e-002 pass 4000 4000 4 0.314 135.8601 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.313 136.2905 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.312 136.9157 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.311 137.1751 1.565487e-011 3.412126e-002 pass 5000 5000 4 0.590 141.2435 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.592 140.8687 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.590 141.3670 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.592 140.9005 2.512907e-011 3.504046e-002 pass 10000 10000 4 4.280 155.7971 1.012627e-010 3.570624e-002 pass 10000 10000 4 4.275 155.9875 1.012627e-010 3.570624e-002 pass 15000 15000 4 15.932 141.2575 1.979849e-010 3.118294e-002 pass 15000 15000 4 16.082 139.9325 1.979849e-010 3.118294e-002 pass 20000 20000 4 32.094 166.2039 3.564028e-010 3.154945e-002 pass 20000 20000 4 32.116 166.0878 3.564028e-010 3.154945e-002 pass 25000 25000 4 63.792 163.3114 6.220813e-010 3.537553e-002 pass 25000 25000 4 64.971 160.3481 6.220813e-010 3.537553e-002 pass 30000 30000 4 117.158 153.6544 9.270371e-010 3.654390e-002 pass
4.8GHz 3.8GHz Uncore - shut my motherboard down, the heat was insane. There is no way my cpu cooler can cope with this...
Code:=================== Timing linear equation system solver =================== Size LDA Align. Time(s) GFlops Residual Residual(norm) Check 1000 1000 4 0.027 24.4817 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 116.9661 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 113.6987 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 115.8336 1.002198e-012 3.417754e-002 pass 2000 2000 4 0.035 150.8695 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.035 151.3860 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.034 155.2040 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.036 149.4019 4.327261e-012 3.764187e-002 pass 3000 3000 4 0.104 173.0388 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.107 167.7035 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.104 173.6963 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.103 174.1454 9.653528e-012 3.717342e-002 pass 4000 4000 4 0.229 186.4405 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.231 184.9304 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.229 186.1771 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.229 186.1232 1.565487e-011 3.412126e-002 pass 5000 5000 4 0.433 192.4411 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.434 192.2064 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.433 192.6871 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.434 192.0620 2.512907e-011 3.504046e-002 pass 10000 10000 4 3.169 210.4104 2.977802e-008 1.050003e+001 FAIL 10000 10000 4 3.158 211.1710 9.805032e-011 3.457353e-002 pass
211 flipping GFLOPs? Are you kidding me?!?! This is with it throttling and failing!
4.6GHz core 4.6GHz Uncore
Code:=================== Timing linear equation system solver =================== Size LDA Align. Time(s) GFlops Residual Residual(norm) Check 1000 1000 4 0.032 21.0860 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 112.8623 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 114.3003 1.002198e-012 3.417754e-002 pass 1000 1000 4 0.006 114.0276 1.002198e-012 3.417754e-002 pass 2000 2000 4 0.042 128.4695 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.036 149.8790 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.036 148.4749 4.327261e-012 3.764187e-002 pass 2000 2000 4 0.050 106.6145 4.327261e-012 3.764187e-002 pass 3000 3000 4 0.107 167.7921 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.108 167.2586 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.107 167.7909 9.653528e-012 3.717342e-002 pass 3000 3000 4 0.109 165.8319 9.653528e-012 3.717342e-002 pass 4000 4000 4 0.236 181.2239 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.235 181.8316 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.238 179.4995 1.565487e-011 3.412126e-002 pass 4000 4000 4 0.237 179.8140 1.565487e-011 3.412126e-002 pass 5000 5000 4 0.446 186.8200 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.445 187.3511 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.445 187.2766 2.512907e-011 3.504046e-002 pass 5000 5000 4 0.444 187.6106 2.512907e-011 3.504046e-002 pass 10000 10000 4 3.313 201.2619 1.012627e-010 3.570624e-002 pass 10000 10000 4 3.233 206.2836 1.012627e-010 3.570624e-002 pass 15000 15000 4 11.923 188.7423 1.979849e-010 3.118294e-002 pass 15000 15000 4 11.838 190.1115 1.979849e-010 3.118294e-002 pass 20000 20000 4 24.219 220.2491 3.564028e-010 3.154945e-002 pass
220 GFLOPS D: D: D: D: D:
Chip hit 98C and I closed it, I'm not that crazy!
I don't even know what to think. On the one hand, clearly old tools are ineffectual (all of them), on the other hand what in the heck do I need to test this for? I had a problem with the old tests, they weren't representative of actual loads I used so they made little sense outside of some people wanting to tout their cooling solution... But this?
lolz...
Anyways I'm going to bed, maybe I'll dream happy thoughts where I wake up and every game is optimized like this and I can downclock to 3GHz and get more performance than I was getting at 5.3GHz three hours ago.
Don't forget to check for WHEA errors, they don't (always) cause BSODs so they can be occurring even if you think you are stable. (See sig for simple app to quickly check)
