Iznougoud
Not that long ago I came across two Haswell CPUs; an i5 4460 and an i5 4670K - both running uncomfortably hot, even under relatively light load (90 - 100 degrees celsius when stress testing, i.e. Prime95). Rather than buying adequate aftermarket cooling solutions, I went for the more cost efficient option, and decided to delid both CPU:s.
After the delid the 4460 doesn't exceed 72 degrees celsius when stress testing and rarely goes any higher than 60 degrees outside stress testing. So I would consider the result a success.
The 4670K, however, is a different story entirely. Although not worse, there's only marginal improvement (a couple of degrees) and - for some reason the cores differ wildly, which would suggest a botched delid. I have however re(!)delidded the 4670K 3 times by now, with roughly the same result.
In both cases (pun not intended, but appreciated just the same) I've used "liquid metal" for thermal paste.
Any thoughts on this?
