Here's an email about this problem I told MSI:
I have already checked this issue and will inform our BIOS engineer. We might implement this with our new BIOS release, in the near future.
This problem exist because the duron microcode can only support the following combination you tried. If we get the new microcode we can add it to our BIOS.
We are sorry for the inconvenience.
-----Original Message-----
Sent: Wednesday, March 14, 2001 1:44 AM
To:
support@msi.com.tw
Subject: Multiplier problem with Duron 600
This processor worked fine at 1000Mhz on an Abit Kt7 RAID. I bought the K7T
turbo Raid a week ago and it only boots up at 1000Mhz sometimes. It boots
at 600, the default speed, after shutting down sometimes. I've been on
Anandtech forums and other amd/via forums and all the people are getting the
same problems. Here's one post:
Hi yodel,
I have the same problem (almost) with you (using the V2.4 and V1.0b16). I
did some experiment again and found the "multiplier bug" like you did. I can
do 7.5x133 with my Duron 600 (w/ KT7A), and from what I got by changing the
multiplier I get these results:
6x133=800 (6x133) ok
6.5x133=866 (6.5x133) ok
7x133= fail
7.5x133= fail
8x133= fail
8.5x133= fail
9x133=665 (5x133) ok
9.5x133=731.5 (5.5x133) ok
10x133=800 (6x133) ok
10.5x133=866 (6.5x133) ok
11x until 12.5x=fail
fail=no post/hang
ok=load windows and stable
Weird huh? I already contacted MSI about this and I'll let you know. Btw, do
you have the voltage problem too? On my Turbo-R if I set the voltage to
1.525V, I'll get 1.65V. Set it to 1.6V, I'll get 1.725V and so on.
