Has anyone used this fan?
I haven't tried the coolermaster LEDs, but I've got the fan in the OP, and i've found it very quiet. Can't hear it running, can't hear the difference when i unplug it, and it pushes a good amount of air.I've got an akasa amber 120mm too, and that is about the same lack of noise at 1,000rpm, whether it is pushing the same airflow I don't know, but yeh, the AeroCool one has blue LEDs, in frankly that awesome blue colour. Sure they're pointless, but I like the colour.
I've ordered one of the 140mm to try it out, it was only £9, linkerage
so I'll post some reviewness once it arrives (this could be as late as Monday though, skimped on the postage 😀 )
To the UK'ers That shop seems good btw, plenty of contact/emails confirming orders, and updates to order status, and cheap too, with cheap postage options (that was £1.50ish, within 2 days was maybe £2.50, next day for it was £4.25)
Just a heads up, as rip-off britain can realllly suck at times.
For example, that shop has the scythe ninja plus (with 120mm fan) for maybe just over £40 delivered. @ OCuk it's £40 including VAT, but without postage, which from them will be like another £10 lol.
They've also got the Akasa Amber 120mm's in stock for about £9 aswell...
I've received email updates every step of the way, confirm order...update to processing status....update to despatched status. All is looking good for the cooling shop! 😀
...Zincplated
i've owned his fan for about 1 day because performance-pcs.com sent me this wrong one instead of the xtreme turbing. i actually do recommend it as a good fan with good amount of air for the noise and nice led's. i got the black one with silver blades if u wanted to know. the xtreme versino is ayy loud and causes turbulence noises with my grill. i'm actually looking for a good led fan that would run silent at 12v stock...
