Has anyone seen or used a splashless urinal??
AMCRambler
7,718
31
I've used some that cause a surprising amount of splatter. For the most part though it's how fast you let the pee shoot out. If you just unload on the bastard full force of course it's gonna hit you in the face. Meter it out, gentle stream, etc.
yowolabi
4,183
Originally posted by: nakedfrog
Originally posted by: yowolabi
The one at work has a rounded shape that seems to direct all splash further into the toilet. I tested with different directions and angles and couldn't get any splash to come back out.
You're a looney.
I know it was TMI, but don't act like you wouldn't have done the same when faced with this technological marvel.
kalrith
6,628
7
At some theatre in Branson, Missouri, they put crushed ice in the urinals. No splash whatsoever. It was also fun to try to melt as much ice as possible.
pnad
405
Originally posted by: Tizyler
I think some people may be "put together" with more pressure than others. Whenever I'm using a urinal, I'm cautious as to not hit myself with ricochet.
The smaller the orifice the higher the pressure.
OP has a small peehole.
Stop crawling into the urinal to pee and hit the back wall low at a steep angle. Don't blast the back wall at 90degrees.
bolido2000
3,720
Toilets are sometimes worse when it comes to splashing, but maybe thats because I'm tall (6'1''). I just posed this question because it surprises me that there are no cheap solutions to solve this problem. Someone mentioned a rubber flap, but couldn't really find anything readily available like that. I tried aiming at about 6 inches from the drain. I still got splashed sometimes although less than aiming randomly. It seems that my penis is just good at "releasing" with force. Pee is not the only thing that comes out with force....
EvilYoda
21,198
9
There are certain ones that I've seen that have more efficient bowl designs, but nothing's splash-less without ice or direct drain aimage :p
I have recently seen ones that are flush-less though...a weird coating or material makes every last drop run to the bottom of the bowl, it's kinda weird to look at while you...go.
tfinch2
22,114
Just pee in your pants. Saves time and energy, and you don't have to worry about people bugging you all the time.
AgaBoogaBoo
26,108
Yeah, I've seen the flush-less ones too, it's pretty odd. I wonder how much it costs compared to ones that flush, and how much they save in water costs, repairs to piping for water, etc.
loup garou
35,132
Ice in the urinal rules!
Eeezee
9,922
You get pee all over yourselves when you use urinals? Are people really that stupid that they can't prevent splashing pee with proper aiming?
slikmunks
3,490
Originally posted by: JS80
they have anti-splash pads in certain urinals
i've been to places where the urinals have mats in them that are supposed to keep from slpashing... they don't work too well tho, imho. it's the same as if it's a regular urinal... so i try to avoid it and aim at the sidewall of the urinal... less angle = less splash
feralkid
17,035
5,095
Originally posted by: npoe1
You just need to dynamical adjust your aim, But not always work:(. It?s an art to not splash.
Aim to the sides. :cool:
It's more physics than art, really.
