I tried Puppy, quite amazing - I was up and running and online too in about a minute (from the cd)
so I tried Mint, and it was fast. I don't understand why though if it's Ubuntu! There's no more lag...
guess I shouldn't try too hard to figure it out? 😛
Puppy is a minimalist distro, designed for low-power or older computers, which also loads entirely in RAM, so it shouldn't be a surprise that it's snappy. Just don't expect to find as many available packages as most distros.
That's interesting, but just to clarify, is Mint also 64-bit?
That's what I downloaded as far as I know. How can I verify it?
Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.9.2.8) Gecko/20100723 Linux Mint/9 (Isadora) Firefox/3.6.8
Mint can be downloaded as both 32 and 64, same as ubuntu it just takes longer for the 64 bit version.
I used to always use mint but got tired of waiting for them to come out with the new versions cause it takes them a month or so after ubuntu, this time i stuck with ubuntu 10.04.
I actually got Steam and CSS set up last night using PlayOnLinux. However, every time I try using it, I can play for 30 sec to 2 min and then CSS just closes automagically without notice or error.
Counter Strike crashes as soon as it starts or you join a game.
You most likely have other program(s) using sound. Run winecfg and select only ALSA sound driver. OSS is not the best choice anymore.
For Ubuntu 8.04 and up - kill/disable pulseaudio. It is not compatible with Wine. And will cause all sorts of problems if left running.
Another possible reason - you have "Steam Community In-Game" enabled. It does not work properly on Wine and causes all games to crash. Please disable it in settings -> In-game tab.
Game crashes after a few minutes. You can fix this by putting this file into your "~/.wine/drive_c/Program Files/Steam/steamapps/YOURUSERNAME/counter-strike source/cstrike/resource" folder, or by applying this patch. See bug #7698 for more information.
Game crash after a while
To fix:
Run winecfg, click "Add application...", select "hl2.exe" (doesn't matter which one, only the filename is used, not the path) and click Open. Select "hl2.exe" in the list and change the "Windows version" to "Windows 98".
I haven't got it working yet but last night was a bit too late to spend much time on it.
One weird thing I noticed though is that every time I reboot, Mint switches the audio device. So I'll have it plugged into my sblive and working fine, when I reboot the system is trying to use the onboard audio, so there's no sound. Reboot again and it's back to sblive!
HOwever, if I try to toggle the device myself , it does not actually change anything - I have to reboot to switch it back to the other audio device. WEIRD!
If you aren't actually using the onboard audio, why not just disable it in the BIOS?
I'm surprised Win7 actually has drivers for an SBLive...
